When I bought my first 5-in-1 tool years ago I’m not entirely sure why I got it.
I knew it was for “painting” but other than that, well…
A 5-in-1 is a painters tool and lots of people have them but have no idea what this oddly-shaped item is designed for. The sharp point is a gouge, as in gouging out caulk and paint. The radius cut-out in the blade is for removing paint-saturated roller-covers from the frame. The semi-sharp blade is for both scraping and applying putty/nail hole filler (though I rarely use it for that–the blade is too stiff). You can use it as a screwdriver in a pinch, too. The square end of the blade opposite the gouge is for removing paint can covers. Trust me, it works way better than a screwdriver for paint can lids. You can even use the butt end of the handle to dimple drywall (like where you removed a screw that missed the stud and left a mushroomed hole; I press down hard with a twisting motion…works great.)
But where the rubber really hits the road for me with a 5-in-1 is all the places other than painting that it’s perfect. Its so perfect, in fact, for so many things I carry one in my tool pouch all the time. Here’s a short list:
> The wide, flat blade works great as a shim/lever for moving crown molding into position for nailing.
> The gouge and blade work great together for cutting off/knocking down/scraping off excess spray foam insulation.
> I’ve used it to remove grout and bust out thin-set replacing a broken tile.
> As a wedge, it’ll hold a door open.
> I’ve knocked out hunks of stucco.
> I also use it to back out screws that spin in drywall or while hanging cabinets. Use the blade and a little pressure under the screw-head then use your drill/driver to back the screw out. Works every time.
> Split or cut off shims.
> Scrape up spilled glue.
I re-sharpen the blade periodically, but that’s about all it takes to keep this inexpensive yet priceless tool by my side.
(2 votes, average: 4.50 out of 5)
4 Responses to “5-in-1 Tool: An inexpensive and priceless must-have tool.”
I have had one of these tools in my shed for many years, not sure where it came from either. I never new about the other 4 features of the tool….good post.
It can also be used for self-defense it looks like. That corner looks pretty sharp and could do some damage. Pretty handy tool, how much do they cost at your local hardware store?
5-in-1s are inexpensive…anywhere from 5 bucks to 15 bucks give or take…I even scrape the caked on grass from the bottom of my lawn mower with an old one I have.
