In the early part of the twentieth century, there were several types of wall board materials that were quite different than the traditional interior wall finish - plaster. Most were made with compressed wood fibers or pulp. Some were smooth-surfaced, some manufactured with a wood grain texture and some were striated to look like boards. The wall boards were simply nailed to studs and joists in unfinished work or nailed over previously finished surfaces. The joints were typically covered with thin wood batten strips and the assembly was then painted.
There were many types and several manufacturers, but the most well known product today is Beaver Board. Over a century after this product was first developed, most folks refer to all of these older fiber board products as Beaver Board. Beaver Board just had the best advertising.
In 1903 J. P. Lewis, a paper product maker, glued layers of mat board used for picture framing to make boards for lining his attic. This took place in Beaver Falls, NY. In 1906, he formed the Beaver Manufacturing Company. Later wallboards made of layered wood fibers include Upson Board, Cornell board, Sterling, and Fibro-Wallboard.
Some people claim Homasote, made from recycled paper waste, was the original fiber board wall product. It was originally manufactured for lining railroad carriages, then automobile tops. It wasn’t until 1925 that it was marketed as a building product.
Some other interesting wall board products include Peerless and Utility Wall Board, which were made from cardboard layered with asphalt. Fiberlic was made of fibers from tree roots. Celotex, a name now associated with modern insulation board, was originally a fiber board made from the waste of processed sugar cane.
These products were advertised as inexpensive, light, easily handled and installed as compared to the process of plastering over lathe. It was also advertised as having insulating qualities. One advertisement from the 1920s claimed that when used in chicken houses “hens will lay more eggs in winter”.
I only see an occasional modest home that has all walls made from these early fiber board products. I find it’s used mostly in buildings that were originally secondary buildings like carriage sheds or in summer cottages. The most common place to find it is in the attic of older homes, that wasn’t originally finished.
8 Responses to “Leave It to Beaver Board”
Hi
I have a wall finishing question. My husband and I recently bought a house built in 1947. Down stairs all of our walls are plaster. Upstairs its a different story. Peeling back the wallpaper, we discovered somewhat knotty (and a bit overly nailed installation) horizontal wood walls. The wood also has what appears to be a white plaster in between some of the larger gaps and inside some of the knots. Any suggestions? We got a quote to have drywall cover it up, but its going to cost an arm and a leg. I was hoping you may have a suggestion as to a way we can make these walls beautiful again.
Interesting, I used to live in a very old house in England. It was built in 1760’s and the walls where impossible to hand anything on as they where made of horse hair and chalk! Even a tiny screw would result in a whole the size of my fist!
Interesting post. We have a summer cottage with this kind of wallboard. Construction is exactly as described, with the wallboard nailed to studs and the joints covered with thin wood strips. We think it was built around 1915. The wallboard is mostly in good shape, but some has warped rather badly due to moisture infiltration. I think an advantage over gypsum wallboard is that since this is an unheated building we don’t have the cracking we’d probably have with taped gypsum wallboard and Minnesota temperature extremes.
Does beaverbaord contain any aspestos?
An attic room has beaver board. There is a hole in one of the walls. Is there anywhere that I can get a sheet of beaver board? If not, is there anything comparable that I could use? Thank you.
Walls are a nightmare in older buildings, we have tried everything. We have no opted to not hang anything…
Could the barracks in the Japanese American internment camps have had beaver board as interior walls?
Just as you say, our house in New England, dating from the early 20th century, has lath & plaster on the first two floors, but beaverboard on the third. There is a large label on the back of some sheets from Beaver Products Company, Inc. Buffalo, NY.
