Insulating Foundation Walls
By: Scott Gibson, Contributing Writer
In: home improvement tips, old house construction
1 Star2 Stars3 Stars4 Stars5 Stars (3 votes, average: 2.67 out of 5)
A reader writes: We have a 150-year-old brick house with a stone foundation. There also is an addition with a concrete block foundation on the back. Both of the basements are damp and musty. We want to tighten up the house and insulate the basements, but we get conflicting advice. Is this a good idea? The sill area would be particularly hard to insulate.
Old houses often have lots of air leaks and rarely enough insulation, a combination that makes heating and cooling expensive. Sealing air leaks and adding insulation is always money well spent. This includes foundation walls. But what you want to avoid in the process is making the problem worse by trapping moisture and giving mold a chance to grow.
Foundation walls can be insulated effectively from either the inside or the outside. Several inches of extruded polystyrene foam on the outside keeps the foundation warm and helps prevent condensation inside.
Foam board is easy to add when the house is being built and the foundation walls are exposed. It’s obviously much more difficult after the fact, and the foam can give termites and carpenter ants a convenient way into the house. For these reasons, it’s probably easier to add insulation to the inside of the foundation walls.
One approach comes from the Building Science Corporation, a consulting and design firm that specializes in energy efficiency and building performance. Its solution is to add rigid foam insulation to the inside of the foundation and seal the seams with housewrap tape. This keeps most of the warm, moist air in the basement away from cooler foundation walls.
Add strapping over the top of the insulation and then gypsum drywall. This wall allows any moisture that does accumulate against the foundation wall to dry to the inside.
A suggestion you might hear is to build a wood frame wall on the inside of the foundation, insulate it with fiberglass batts and add a polyethylene vapor barrier to keep moisture away from the foundation. Don’t do it. Although the plastic keeps some moisture out of the wall, some leaks are inevitable, and the plastic traps moisture inside. This leads to rot and mold. Building Science maintains an excellent website where you can read more on this and other energy subjects (www.buildingscience.com).
Insulating the sill (also called the rim joist or band joist) is difficult. You can stuff fiberglass insulation into the framing and cover it with a plastic vapor barrier. But this is not going to do a great job. Spray-in polyurethane insulation would be much more effective. Closed-cell foam not only has very high R-values, but it also makes a good air and vapor barrier at the same time. The two-part foam fills nooks and crannies and seals off leaks better than anything else.
Polyurethane foam is usually applied by trained insulation contractors, and it’s fairly expensive. For smaller jobs, you can buy a kit that allows you to do the work yourself (one such company is at www.fomofoam.com).
  1. 3 Responses to “Insulating Foundation Walls”
  2. Daniel
    Mar 26, 2009
    Insulating the inside of a stone foundation is a really, really bad idea. Old foundations need regular inspections and maintenance (repointing, etc).
    Building Science Corporation’s recommendation certainly shouldn’t be considered for anything other than modern concrete foundations that were constructed with proper exterior waterproofing and effective drainage systems.
  3. Mar 26, 2009
    I agree with Daniel. Trapping moisture will rot the old foundation. You can create a dryzone on the exterior. All of the old foundation that I have repaired, regrading the exterior is critical.
  4. Scott Gibson
    Mar 27, 2009
    I was assuming the foundation wall was dry, sound and not in need of any repairs. So Daniel and Randall make a good point, especially if the foundation needs repointing now or is likely to down the road.
    Foundations can be waterproofed and drained from the exterior, although it’s often complicated and expensive because of the excavation that’s required.
    In this case, the lesser of two evils might be to skip the insulation on the stone portion of the foundation, and insulate the floor above the basement instead.
    But, if the basement is chronically wet, those problems should be addressed separately. Options include footing drains, a sump pump, covering any exposed dirt with polyethylene, and running a dehumidifier.
