Drywall compound shelf life
Postby andrewro on Wed Apr 11, 2007 4:50 pm
Here's my question of the day. I have one of the big tubs of drywall compound - I bought it in December and have only used a little bit of it. I noticed the Litchfield book "Renovation" claims a one month shelf-life for drywall compound once it's opened, so long as it is kept properly moist. Is this really the case, and how can I tell if it's still good to go?
Thanks!
andrewro
Postby BrooklynRowHouse on Wed Apr 11, 2007 5:26 pm
It's generally not a good idea to use old joint compound because the hardener degrades with age and exposure to air leading to a "dusty" joint. It can also harbor mold spores.
BrooklynRowHouse
Postby andrewro on Thu Apr 12, 2007 9:14 am
What constitutes "old" - I've read one month, six months.... This is about four months old.
andrewro
Postby BrooklynRowHouse on Thu Apr 12, 2007 10:18 am
andrewro wrote:What constitutes "old" - I've read one month, six months.... This is about four months old.
I suppose it depends on how tight the container was sealed, the dampness and temperature of the storage area, whether it was misted down before storage, etc.
I used four or five month old joint compound during my kitchen rebuild. I had built a brick eyebrow to the dining room and left the scaffolding up for several weeks to ensure decent curing of the mortar:
http://www.brooklynrowhouse.com/house/kitchen
I couldn't hang the drywall till I removed the scaffolding so that was one of the last steps in the renovation. I'd hung, taped and primed the other drywall months before and had leftover compound from that job. Since I only had three or four short joints to tape I didn't want to buy fresh compound.
What I found was that I couldn't get the compound to knock down as flat as fresh compound. After probably five applications I had a small mountain of compound.which you could plainly see in a side light. I'm pretty good with a taping knife so I knew it wasn't my technique. It had to be that the compound had thickened and even diluting and remixing it didn't help.
I had two choices, both of which involved buying fresh compound: skimcoating the wall or retaping it. I chose the latter because I wasn't sure how well a heavy accumulation of compound would hold up in the steamy climate of a kitchen. I had visions of the tape popping one day while boiling pasta.
BrooklynRowHouse
Postby h7432 on Thu Apr 12, 2007 11:53 am
My dad is a taper and the mud will keep for quite some time. If it is not the consistancy you want you can mix in some water with a drill but if you don't know what you are doing I wouldn't recommend it. Also, he only uses the mud in the bucket when he puts the tape on. The top two layers he uses a powder he mixes. He calls it Plus 3. It's much easier to sand.
Jill- Morocco, Indiana
h7432
Postby Tujo on Tue Jan 08, 2008 6:16 pm
Mud will last, but i've noticed old mud starts to get a lot more "chunky" and it doesn't seem like mixing it will get these chunks out. These chunks make mudding a huge pain.
Tujo
Postby plastrr385 on Wed Jan 09, 2008 12:13 am
I'm not sure on shelf life but if you clean the sides of the bucket down during use and I cover the mud with enough water to cover it it should last just pour off the water before next use and remix.Thats as long as it dont freeze.
Nice run on sentence HUH!!!
plastrr385
Postby BrooklynRowHouse on Wed Jan 09, 2008 12:26 am
I keep the paper cover that comes with the joint compound. When I'm done for the day I hit the mud with a few squirts from a spray bottle and replace the paper cover before closing the bucket.
Unfortunately, this isn't a permanent fix either. After a few months you'll have a healthy mold population growing in there.
BrooklynRowHouse
Re: Drywall compound shelf life
Postby Nnamlets on Sat Jun 13, 2015 4:57 pm
Experiment: Use of leftover 10 year old drywall compound mud.
User: Homeowner, minimal experience, 2 days Habitat for Humanity volunteering drywall mudding and sanding, then 1 day repairing own home drywall.
Materials:
Used: Westpac Materials Taping and Topping Compound “TNT” purchase date 9/22/2005 first opened 6/6/2015. Consistency: firmer than fresh premix, about like “Play-doh.” Thinned out with small amount of water for test use. Color: light tan.
Comparison: Sheetrock Brand All Purpose Joint Compound purchase date 4/7/2014 first opened 2014. Re-opened 6/7/2015. Consistency: moist paste, unthinned. Color: white.
Testing : 5/8” scrap drywall removed from damaged wall, painted side down, cut it half, separated by 1/8” gap, screwed down to scrap wood. 6/13/2015 Photo labels:
“1”: 6/6/2015 gap filled with 9/22/2005 mud.
“2”: 6/7/2015 joint taped with 2005 fiberglass tape topped with 9/22/2005 mud.
“3”: 6/8/2015 top layer 9/22/2005 mud.
“2005” left: 9/22/2005 mud top half inch layer discarded: grey/brown/black speckled/discolored, faint musty smell disappeared after 24 hours, no odor thereafter.
“2005” middle: 9/22/2005 mud after top half inch scraped off.
“2014” right: 4/7/2014 mud for comparison
Results: So far only difference I can tell between 9/22/2005 mud used on test materials and 4/7/2014 mud used for 6/2015 repair to my house is slightly tan color, less apparent when dry. Otherwise seems to work ok. No noticeable odor when dry.
Comment: use at your own risk. I am not a professional. I would not use obviously smelly / moldy old mud described by others. Results may be more favorable due to ten year old mud never having been opened.
Nnamlets
Users browsing this forum: No registered users and 17 guests
