Repairing White Marble Fireplace Mantel
Postby dalmatiangirl61 on Mon Oct 18, 2010 3:04 pm
Does anyone know how to repair broken white marble? My neighbor purchased a white marble fireplace mantel that has several broken pieces, the breaks are clean and fit back together fairly tightly. Of course the only reason she bought it is because she knew I would know how to fix it :lol: . So lets not disappoint her.
Kristin
McGill Clubhouse
dalmatiangirl61
Re: Repairing White Marble Fireplace Mantel
Postby Julie&Glen on Mon Oct 18, 2010 5:39 pm
I have seen some shows that covered marble repair. What they do is cut two parallel channels in the back into which they placed re-enforcing rods embedded in epoxy. A color matched epoxy is used to fill the actual crack. Pipe clamps are used to hold the pieced together tightly while the epoxy sets. Once the pieces are assembled and the epoxy is completely cured, you will need to polish the front of the piece to remove any excess epoxy. The cracks will be almost invisible. Good luck.
Julie&Glen
Postby Old Colonial on Mon Oct 18, 2010 7:17 pm
Kristin,
I would contact someone who does granite kitchen fabrication to find out what epoxy product they use. I had a farmers sink made from granite. Not only does it have to stay together, it has to hold water.
Jeff
Old Colonial
Postby sooth on Mon Oct 18, 2010 7:49 pm
I agree with Jeff. Contact anyone who works with granite counter tops/marble and they would be able to reglue the breaks using their specialized epoxy resin (regular epoxy will turn yellow in a few months).
JC
1923 Foursquare
sooth
Postby Julie&Glen on Mon Oct 18, 2010 9:59 pm
sooth wrote:I agree with Jeff. Contact anyone who works with granite counter tops/marble and they would be able to reglue the breaks using their specialized epoxy resin (regular epoxy will turn yellow in a few months).
Agree that you can't use just any old epoxy. One used that I saw was specifically formulated for marble repair. I wouldn't suggest using an epoxy designed for granite on marble. Marble is much "softer" and pores than granite.
Julie&Glen
Postby cs on Tue Oct 19, 2010 8:19 am
I've used a marble epoxy while installing my soapstone counter tops & fireplace surrounds. In my case it was black (to match the soapstone), but I'm sure you can get white. The bond is super strong, and nearly invisible. In the case of a repair to a break (which would have an irregular seam) it would be very hard to spot. The brand I used was Akemi ( http://www.akemi.de/en/products/stonerange/ ), and I purchased it from the stone supplier. It had a toothpaste-like consistency.
Hope that helps!
http://www.saracenihouse.com
cs
Users browsing this forum: Google [Bot] and 9 guests
