1883 Schoolhouse, rural Ontario, Canada
downtowndahlgren wrote:I'm a HUGE fan of linoleum rugs, and have bought and sold them as well. They're impervious to water and pet stains, and the old patterns look gorgeous. Your best bet is to keep it waxed to maintain it; if you want to be truly period-perfect, you can find intact cans of linoleum floor wax on eBay, but any good colorless paste wax will work. I do that and then just vaccum mine and Swiffer it when it gets dirty.
Question: I recently purchased a linoleum 1930/40's "rug" from Secondhand Rose. Very beautiful rug and very nice people...but the linoleum is fragile. Was wondering if you (or anyone) has any suggestions on preserving and maintaining old linoleum.
Answer: by Glenn/Sohm Flooring Consultants
These products require very special handling, which is a service I supply. I have installed several rugs which were purchased from Second Hand Rose.
I have tested several waterbased urethanes in the search for one that would bond well, not change the color and would match the gloss level. I'm still looking.
I have used Armstong's Shinekeeper® floor polish as a "sacrificial coating" on one particular installation. It did give a higher gloss to the rug's surface, however it bonded well and will give some protection to the surface. Shinekeeper® is removable by using Armstrong's New Beginnings®, but I would exercise extreme caution and test it on a small inconspicuous spot first. I don't have any experience with that product and these rugs.
Other than that suggestion, just keep grit off the rug and use high quality felt floor protectors on any moveable chairs, etc.
Question: What do you mean by "sacrificial coating?" And if I treat/seal vintage linoleum in situ, can it ever be removed thereafter? (not that I would want to, just curious)
A "sacrificial" coating is an applied-on coating to a product, the primary purpose of which is to protect the surface on which it is applied, and which is not intended to be permanent, such as is the case with polyurethane or epoxy. A sacrificial coating is worn off as the product, in this case the floor, is used. These coatings are polymers, but they are removable. Instructions for removal are usually found on the product label.
I have discovered that there are many different "species" of enamel rug material, and a prescription for removal of a sacrificial coating should be on a case by case basis, only after thorough testing. Hope this helps. Glenn Sohm
Users browsing this forum: csnyder, Google [Bot] and 7 guests
