Window trouble
Window trouble
Postby saibari on Sun Jan 29, 2017 4:09 pm
We had a contractor install new windows/screens and the screens have gaps in them at the bottom. The contractor and manufacturer insist that this is the way the windows are designed. This is unacceptable to us and we've never seen screens like this before. This is a reconstruction from fire damage and were not given any options in selection nor the opportunity to view the windows/screens before installation. Have any of you seen anything like the attached pics before??
saibari
Re: Window trouble
Postby CarolCPalmer2016 on Sun Mar 12, 2017 11:59 pm
Screens may be nylon or metal suspended by a wood or aluminium frame. Even if we may manage to stuff the edge of the screen back where it belongs, it will just pull loose again.
The best solution would be sealing the gap using an additional, thinner frame on both sides, sandwiching the screen between two pieces of wood. Installing fir pieces all the way around the perimeter will result in a sturdy frame.
I would suggest you take help of some professional services in filling the gap and more importantly, any reliable window services who are trustworthy. Try taking expert guidance from windows and doors company modena, canglow windows and doors inc. Recently we had all our windows installed by them.
If you desire to DIY you can purchase an adhesive foam strip to fill the crack. They are easily available at most home improvement stores which come in different widths and thickness.
My friend once used something called Mortite, skinny putty kind of fill in the gap after breaking off as much as you want.
CarolCPalmer2016
Re: Window trouble
Postby ljnealandsons on Fri Apr 21, 2017 11:17 pm
Try Alside or Anderson windows, they are so rigid and long lasting. Comes with great designs and also affordable.
ljnealandsons
Re: Window trouble
Postby Geraldine on Wed Nov 08, 2017 7:16 am
These gaps in the window film are seen many times. You can take an insulating fiber and install it taking additional info from the professionals. These window films are easily available, less expensive and provide complete insulation. It will be a one time installation that will give your house complete protection.
Geraldine
Re: Window trouble
Postby jasminsamith on Wed Nov 29, 2017 3:10 am
very nice information
jasminsamith
