Hello! I’m in a bit of quandary here in regards to how best to approach insulating the roof of my 1842 brick home.
Simply put, we have a third story that we don’t use. We don’t use it because it is in a state of disrepair. It has been on the project list for years and my wife and I have decided to get serious about it this year. I have plans to renovate it, not as a living space but as a clean and comfortable area for storage and space for my wife’s various crafts. The current roof system is as follows: typical a frame, rafters, purlins, original cedar shakes nailed directly to purlins, standing seam metal roof applied directly over original cedar shakes. No roof insulation. I’m not sure when the metal roof was installed, but I have to assume it’s old. No ridge vent, no soffit vents, no roof box vents, no gable vents, no venting whatsoever. How can I insulate this? I’ve read plenty of things online regarding this issue, I’ve spoke with my local building inspector, a residential architect, and the cedar shake bureau technical rep. The idea of not installing vents and applying closed cell foam to the underside of the original singles (possibly with a contact barrier in between) is debated. Some say you can, others say you can’t. My options are to explore this route (waiting to hear back from a reputable insulation contractor) or to have a ridge/soffit system installed and use fiberglass batts. Historic preservation is very important to me. I would rather not use spray foam if I can find another option. The toxicity of it, the permanence of it, and the idea of spray foam against 180 year old rafters makes me cringe.
That comes to my second quandary. Current code in my area (NJ climate 4a) states roofs must be insulated to R-49. This can be achieved with fiberglass batts at 14” thick. As far as I know, my 180 year old roof rafters are 4-6” thick. There’s no way that could work. And I seriously do not want to extend my rafters by 10 inches – it would have a huge spacial and visual impact on the third story (sloped walls/knee walls and chimneys coming through). Even with closed cell foam, using the max allowable thickness of 4-5 inches (I believe) I would fall quite short. I’m looking at the NJ rehab sub code which I believe states an exception in my case – stating that if recommended R value cannot be achieved due to space constraints, fill the available cavities. Which I interpret as put as much insulation as you can in there. But, unfortunately the inspector may interpret it differently and state I “could” achieve this by undertaking more construction and increasing the depth of my rafter bays. I don’t care about meeting code requirements and hopefully the renovation sub code will excuse me from doing so. Furthermore, historic preservation and using traditional, or at least more natural products (mineral wool, havelock wool) is more important to me than energy efficiency. I like my old drafty house and noisy radiators just fine.
Any thoughts at all would be welcome!
Roof insulation
Re: Roof insulation
To start with, are those rafters (180 years old) are still good or they would need to be replaced ?
Re: Roof insulation
Well I haven’t truly inspected them. I’ll have a better look once some of the plaster is taken down. I hope they don’t have to be replaced. They’re 24” OC which obviously not the standard nowadays.
Re: Roof insulation
Rafters appear to be in good condition - dry, no sagging, and the ridge appears straight and even. Furthermore, I have no desire to replace them or anything that isn’t necessary. The rafters are 24” OC.
