Hi everyone. Great forum, really informative.
I have an 1868/70 house that was completely abandoned a couple of years before I bought it. I'd say it was also badly maintained for about 30 years before that. I'm putting it back together bit by bit. This summer has been moisture control at the foundation.
In the basement -- probably a crawlspace converted to basement when contemporary ("modern") heat and plumbing were installed -- I've repointed the rubble walls with lime mortar, filling voids and replacing broken/ missing stones etc. On the outside, I dug down about two to three feet around the house and removed impacted soil/ roots from the mortar joints and repointed the exterior walls. (Deeper than about three feet, it's hardpacked clay. Based on test holes, it hasn't compromised the mortar.)
All around the house, I removed about a foot of soil that had accumulated against the brickwork, returned the elevation to just below the top of the rubble stone foundation, and graded it away from the house. (That was a lot of work.) The basement is much, much drier.
However, the house doesn't have gutters, never did, and I can see where rain coming off the drip edge is compacting the soil and, I assume, is sending water toward the foundation. The situation is worst at the roof corners, and I do notice that the basement gets wet at those spots. I do not want to install gutters because it will ruin the cornice moldings on the house and I can't imagine getting up 30+ feet every year to clean them out.
It has been recommended that I install a french drain/ tightline along the drip edge of the house and attempt to channel the water away from the drip edge and into the open yard. Has anyone done this? Is it advisable? Has it worked? What did you do?
Thanks.
