French Drain/ Tightline Around Rubble Foundation?
Re: French Drain/ Tightline Around Rubble Foundation?
Postby Detroiter on Tue Aug 16, 2011 9:36 am
Thanks, angolito. I'll have to take some new pics in the next few days and post them.
Yes, in Detroit: there's no shortage of houses to fix up around here!
Detroiter
Postby Detroiter on Sun Oct 14, 2012 12:22 pm
A few days. . . sheesh.
I finally got around to the French drain this summer. Under the roof's dripline, I dug about two to three feet down, about 18" wide, and continued out about ten feet from the house. I lined the trench with soil separator and used solid pvc pipe under the dripline and perforated pvc in the yard. I filled it all with gravel. Under the dripline, I brought the gravel to the surface to avoid compaction and covered the yard portion with soil.
Last year, I dug down around the foundation about a foot and a half (where the soil was a mess, anyway) and repointed the stone foundation. I also repointed inside the basement. During both of these projects, I continued to slope the grade away from the house. With these improvements, there's no more water coming through the basement walls.
The basement floor is dirt with bricks, so I still have to dig down, put in a vapor barrier, and pour concrete. It's a small basement, but that's a project for another summer.
Detroiter
Postby michaelskis on Mon Oct 15, 2012 9:55 am
I have been thinking about doing something like this for my house, but I don't know where to send the water. The worst section of water leakage is on the east side of the house where there is a 4 foot side planting bed and a 9 foot wide driveway.
Based on the suggested slope, I would have to install a drywell someplace on the property to provide a place for the water to run to. Event then it would result in substantial excavation , including under the back porch as every other place is paved on that side of the house.
Any suggestions?
1890 Edmund Barry House
Heritage Hill Neighborhood
Grand Rapids, Michigan
michaelskis
Postby Sashguy on Mon Oct 15, 2012 8:22 pm
My 1936 was sinking due to the home being built next to a buried spring. In fact, I discovered the capped spring while installing the drain system. Not wanting to disrupt the compacted soil, I laid a foundation drain, consisting of 2" slit top PVC set in a mortar bed at 1' depth tied into a conventional French drain starting at 2' depth. Each 3' a crossover line is set at a 45 degree angle to offload the smaller foundation drain. This was five years ago and I still smile during every rain shower as I watch all of the water flow away from the house. I also set gauges to monitor any additional sinking. Zero to date.
Sashguy
