Crawlspace and Floor Joists Questions
Postby kbaird4939 on Thu Sep 29, 2011 4:37 pm
Good afternoon--
I've been a lurker for a good long time, and have learned so much from you all. A life-long old house lover, I recently found one that I really like, as a second home, but have concerns as far as pursuing it further. My next step is to hire a contractor to go over the house with a fine tooth comb, to give me an estimate, before I consider making an offer. The house is also about 6 hours' drive from where I live. (Warning: This post may be a long one).
The home is in a mountainous region, on 1/2 acre, 1100 SF. The major parts of the lot slope probably between 15 and 25 degrees.
The original one room home was built in 1890, on what appears to be a stone foundation over a crawlspace. No access the the crawlspace.
The home has been added onto, at least 3 times. One other room seems to be on the same type of crawlspace (also no access), and has a significant slope, bounce, and mushy feeling towards an outside wall. Another, newer room joins this area, at right angles, with a badly flashed roof at the valley above, and no guttering. The newer room has a slab foundation.
The other rooms of the house are also pier and beam, with a more accessible crawl space, due to the slope of the land.
Other than the section that is accessible, the earlier parts of the house need to be regraded so badly the foundation is not immediately visible, ie the ground covers it. The house is asphalt shingle over wood clapboard siding. The lowest course of shingle touches, and in some cases, is in the ground.
Because the foundation walls were covered, there was no visible venting of the crawlspaces; if they exist, obviously they couldn't do their job.
So, with all that: Do I need to assume the worst, that because of the grading, no gutters, no vents, mushy floor, that most, if not all of the floor joists will be damaged? And if, once excavated, the crawlspace is minimal, that all the flooring (original wood, I think) will need to come up to make the repairs?
And the sill plates: Should I assume they are also damaged? All the walls appeared solid, it's a mix of plaster, fiberboard (I think) and drywall. The corners, inside and out, seemed square (as much as an old house can be) with no obvious leaning in or out.
I do apologize for being so wordy. I really want to be prepared for what may happen, and not get my heart set on this house.
A picture for a thank you!
Kelly in Texas
Sept 23 143A.jpg (64.82 KiB) Viewed 227 times
kbaird4939
Re: Crawlspace and Floor Joists Questions
Postby s.kelly on Thu Sep 29, 2011 6:02 pm
I hear two or three things that would probably send me away from that one. I do most of my own work, so it is time more than money. With a contractor you would probably end up with lots of money in that one.
Unless you can see otherwise, the places you suspect damage probably are. And IMO if you expect the worst, get involved anyway, and it is not so bad that is a pleasant surprise. The other type of surprise is a bad one.
Again, IMO some of what you described is close to worst case scenario for future life of the building. But based on what you pointed out, I think you know that. Grading and foundation issues are raraly cheap, lots of expensive toys to do that work. Roofing also is expensive when you have to hire it out.
But, if you like it get it checked out, and remember they will find something unexpected. There always is.
s.kelly
Users browsing this forum: No registered users and 4 guests
