Inside corner plaster repair
Postby chooseopen on Wed Dec 14, 2011 4:43 pm
Hello,
I have a crack on an inside corner of an outside wall (a gap really) that I need to repair. Some PO had filled the crack with caulk. I have chipped out all of the hard brittle caulk which has left me with a crack of about 3/8" wide. Its gets to about 1"' inch wide in a couple spots where the plaster had crumbled. The crack is about 1" deep when I insert a screwdriver and runs the entire 11' height of the wall.
Of note: When removing the wallpaper, I found evidence of minor surface mold which indicates to me that cold air is coming in through the crack causing condensation in the area.
How should I repair it? Simply putting up mesh tape with a couple layer of joint compound seems inadequate to me. Couple of ideas I had for filling the crack were: joint compound, caulk, or expanding foam
Suggestions?
(click to enlarge)
Thanks!
Jason
Jason Elwell - Canton, IL
My 1896 Victorian - Follow our progress on our Blog
chooseopen
Re: Inside corner plaster repair
Postby mfglickman on Wed Dec 14, 2011 5:27 pm
I don't know about historical correctness but tape and mud would do the trick. Assuming you're going to paint or otherwise treat the walls after removing the paper.
A 1" wide crack will be hard to fix with joint compound alone. And none of these materials will fix a cold wall, but you know that. :)
"The Revolutionary Cottage" ca. 1758 in NW CT
mfglickman
Postby dalmatiangirl61 on Thu Dec 15, 2011 4:51 pm
I'd fill the crack with plaster, then mesh tape the corner, then skim coat the mesh.
Kristin
McGill Clubhouse
dalmatiangirl61
Postby plastrr385 on Sat Dec 17, 2011 5:01 pm
1 Pack durabond in the corner and let set
2 Use papertape in the corner and apply 3 coats of joint compound
3 Sand and paint
OR
1 Brush out the loose plaster and bond
2 Fill with Lime and gauging
3 Smooth using paintbrush with water and putty knife as it sets
Hope this helps
plastrr385
Postby Sombreuil_Mongrel on Sat Dec 17, 2011 10:19 pm
An alternative:
Foam the crack with spray foam insul., remove excess. Using Durabond, set a preformed metal inside corner, the kind with paper bonded to it. These are immensely strong compared to paper or mesh, and it's more moisture-excluding because of the foam insulation.
Ravens!!! Yeah!!!
Users browsing this forum: Bing [Bot] and 2 guests
