wind bracing?
wind bracing?
Postby farmerjohn on Fri Apr 13, 2012 8:49 am
Anyone got pictures of a house with wind bracing? Was wondering if my house had them.
farmerjohn
Re: wind bracing?
Postby shazapple on Fri Apr 13, 2012 12:45 pm
You can see the wind bracing used in my house from my bedroom renovation. Some good examples near the bottom of the page
viewtopic.php?f=2&t=28446&st=0&sk=t&sd=a&hilit=bedroom&start=10
1902 (ish) Cottage
Addition project!
shazapple
Re: wind bracing?
Postby downtowndahlgren on Sat Apr 14, 2012 4:04 am
So the wind bracing is the diagonal 2 x 4's between the studs? I guess without taking down the interior walls there is no way to tell otherwise. Am I correct in thinking that your house has no exterior sheathing, Shazz - just the clapboards?
downtowndahlgren
Re: wind bracing?
Postby shazapple on Sat Apr 14, 2012 8:18 am
The siding has a bit of a shiplap, so there may be some sort of bracing there.
You could use a stud finder, or a thermographic camera to see if you could find them.
1902 (ish) Cottage
Addition project!
shazapple
Re: wind bracing?
Postby Don M on Thu Apr 19, 2012 12:04 pm
I've also seen diagonal 1 x 6 bracing in the corners of buildings then covered by sheathing & siding. A lot of new construction simply uses 4 x 8 sheets of plywood.
Site Admin
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
