Thanks so much for the nice complements, really makes a difference for me.
I got the spare pieces from a place locall called Jacks, they specialize in old house parts.
I guess availability has a lot to do with area. Our 20's houuse is old for this area and there aren't a lot being wrecked , But the land value is high, so there are some getting ripped down to build larger. I would think this would be a different scenario in say the midwest US or other areas where there was a higher population.
I spent the weekend on it , I had previously filled any sizable cracks with latex filler using a jumbo syringe. I used the putty for outdoors. I always wondered why they even sold the indoor type putty? the putty stood up pretty well through the acid treatment but there was some imperfections. I did a coat of danish oil , that gave me a better look at the color the wood will be.
I went to the place I get supplies from and asked him ( Mohawk finishing supplies) the guy there is quite knowlegable.
I got some oil based putty to use now there is oil on the floor. I am using pigmented toners to adjust the color. It came quite thick so I mixed in some acetone to thin it a bit. Oh I asked him why they even sold the indoor type putty and learned that the outdoor putty won't take stain as well.. so that's why they have two different kinds.. makes sense. I had started just always buying the outdoor one after I absent mindedly used the indoor kind on my balcony railing.. don't do that
I've been going over and for any gaps I still don't like.. I put a piece of masking tape along either side of the crack, then use a little spatula to fill the small gap between the two pieces of tape and pull the tape off while it is still wet. after it's dry I can use some more danish oil to keep my sandpaper wet to level the putty without dry sanding. I used a whole roll of tape and started going bug eyed from laing it alongside each crack.
Now I have a layer of clear oil down ,I mixed 3/4 of a gallon and a quart of cherry colored oil, and about a cup of dark walnut danish oil. that gave me a weak concoction of colored oil. I will do a second coat with that and at the same time level any putty patches off.
at this point it is getting a bit fiddly. some dark spots I touched up by gouging out and filling. That's a slippery slope though as it could get to be never ending and some marks and spots are inevitable. I think I will do the coat of colored danish oil and if the stuff that is left still bugs me I could spend more time at it .
I have heard that one shouldn't fill every crack because of expansion/ contraction. . I did fill most of them anyway. I did the same upstairs with no bad results. It could cause buckling I suppose but I think with a good coating of poly the floor isn't going to change size too much. I like the feeling of getting it smooth with no cracks it will make it easier to clean. If it buckles it's my fault..
Phil
