by udsibe on Sun Nov 08, 2009 11:33 am
Our house is 1920's, but problem is with our relatively new bathtub, installed in 2002. The drain opens & closes with a little lever & the lever is loose like it's not connected to anything. The flap it's supposed to be attached to, that closes the drain, is stuck almost in a closed position so that it takes hours for the water to drain after a shower. What I need to know is how to remove, to either repair or replace, the mechanism that controls the opening & shutting of the drain. Any help would be appreciated. Thanks in advance.
