This is the house as it sat on a mover's lot....where it had been for 6 or 7 years. I had called about it when it first came on the lot, but was told it was sold. Still, it sat for years, and after Hurricane Ike, the front door blew in, and I went back to see it again. I called about it and was told the owner couldn't get it moved. Months later, we found out the reason. He was in prison.
It looks awfully rough....had been a brick house and water seeped behind the mortar and caused some rot. Bricks were removed to move it and it had sat cut in half for all those years. It is an L shaped house, so was cut in the middle bedroom,
right where the top of the L joins the bottom.
Here it is, coming onto our land.
They did a good job of putting it back together, especially considering how long it had been cut in two and was slightly warped.
We built a porch across the front.
We built a sunporch and mud room inside the L.
We put Hardie plank on it and used these old windows in the gable ends that I've been saving for 20 years.
The room that was cut in half, we framed into an addition to the bathroom, and the other part, computer room. This window that goes in the area beside the toilet, is one that I have saved for 30 years.
The house had been advertised as an old farm house...had been the foreman's house on a large ranch near here. It was built from debris left over from the 1900 hurricane that almost wiped out Galveston. It has 3 x 12 floor joists, and it is as solid as a rock....although I know that looking at the before picture, you wouldn't think that.
We found a house that was being torn down and was able to get the hardwood flooring out of it and enough beadboard to do
the part of the bathroom where the tub will be. (I have lived for 13 years without a decent bathroom, and I want a nice,
big one in this house. One part will just be for the tub, and the other part, made where we framed up the cut in the house will be for the toilet, shower, and lavatory. We have enough flooring to patch where needed and enough to do the sunporch too. We also got 30 2 x 6 fir sills, a door, and a few windows...all for $200.
I can bore you with more pictures...but this is enough for now.
