Fall-Arrest Safety Anchors
Re: Fall-Arrest Safety Anchors
Postby gluby174 on Tue May 22, 2012 9:10 pm
Never Ending,Please be carefull,the first thing I purchased after buying my house was pipe scaffolding and planks.I knew I had alot of high work to do.After weighing it out ,it was cheaper to buy then rent,was the best investment I did.
Fall protecton is a good idea but a better fit for roof work.It allso pays to have good ladders,heavy aluminum or fiberglass.
To tell the truth a am not a big fan of heights,the scaffolding made me feel safe,Gene
gluby174
Postby shazapple on Wed May 23, 2012 9:35 am
chooseopen wrote:Shazapple,
I am with the original poster here... I want a harness to catch me in case I fall off the 30ft ladder or somehow slip off my scaffold. It sounds like you think that the harness is unnecessary when using a ladder or scaffold. Is there some other method of protecting yourself from falling all the way to the ground when using a ladder/scaffold?
I think it's an excellent tool... when used properly, which includes thinking about what happens after you fall. You can't assume you or your helper can save you and you can't assume the fire department can get there in time. You need a rescue plan that consists of trained people and expensive equipment, which i think are out of the realm of the average DIYer. Even most roofing companies avoid harnesses in favour of simpler methods.
The best method to protect yourself from falling is proper setup and use of scaffolding or ladders. Good guardrails and planks for your scaffolding that is anchored to the building. Proper setup for your ladder; 1:4 slope, solid ground, both rails supported, 3 rungs above the supporting surface, tied off at the top (I've seem people use locking pliers on metal flashing and tied to the ladder to stop it from sliding). Keep your weight between the rails, 3 points of contact when you are ascending/descending, keep your boots and ladder clean. Finally, buy a decent grade 1 or 2 aluminum ladder, not the grade 3 home depot special.
1902 (ish) Cottage
Addition project!
shazapple
Postby cs on Wed May 23, 2012 10:04 am
shazapple wrote:I think it's an excellent tool... when used properly, which includes thinking about what happens after you fall. You can't assume you or your helper can save you and you can't assume the fire department can get there in time. You need a rescue plan that consists of trained people and expensive equipment, which i think are out of the realm of the average DIYer. Even most roofing companies avoid harnesses in favour of simpler methods.
I agree with most everything Shazapple wrote. But even with proper setup and use of scaffolding and ladders, accidents happen. Bad accidents. Often, these accidents happen to people who were 100% certain that they had set everything up properly, even if if they were later revealed to have been mistaken. OSHA is satisfied by either "fall prevention" systems (guard rails, safety nets, safety belts etc) or "fall arrest" systems (body harness and anchors). On a fixed ladder, over 24 feet, one or more of these methods must be employed. On a portable ladder, this is not required.
That said, for me, some thought needs to be given to "what would happen if I fell from here" even if OSHA does not require it. If the answer is "certain death", then, for me, I'd rather be wearing a harness and take my chances with the dangling. I used to be an avid climber back in my late teens and early 20's, and I've had my share of fall arrests - some significantly higher then the drop you'd be likely to encounter with a properly used fall arrest system. So I look at it like this: Seat belts, even when used properly, can cause injuries. Still, I buckle up every single time, because I'd rather take my chances with an injury from the belt then be ejected from the car. So too, I'd rather have airbags, even if in some cases, I run a risk of being injured by them. The same necessary evaluation is true for the use (or not) of a harness, IMO.
here are some potentially useful links:
http://www.worksafebc.com/publications/ ... ection.pdf
http://www.osha.gov/pls/oshaweb/owadisp ... p_id=23870
http://www.oseh.umich.edu/pdf/guideline/guidslfp.pdf
http://www.osha.gov/SLTC/etools/constru ... rrest.html
http://www.orosha.org/pdf/pubs/2824ce.pdf
http://www.saracenihouse.com
cs
Postby mross_pitt on Wed May 23, 2012 11:22 am
Approaching this from a different direction, has the original poster considered renting a bucket lift/ aerial boom?
I recall at least one person here that bought one, or bought a used one and then resold it when finished.
Of course, this depends on the access and slopes of your property.
mross_pitt
