Should I Replace the Front Porch Post?
Postby Corydi on Tue Oct 24, 2017 8:30 pm
Hello, my house was built in 1950's. I had a brick column which cracked so I decided to removed them recently. I then found this wood post behind the bricks. The bricks just encased the wood post for all these years.
I'm not sure if I need to replace this wood post now as it has some crack lines. I can't tell if these are the normal check lines. I just want to make sure it's still structural sound as it's the only load bearing post on my front porch. Thanks.
IMG_20171024_162818 (1).jpg (357.99 KiB) Viewed 4831 times
Corydi
