Exterior paint removal
Postby kari74ob on Fri Jun 19, 2015 12:53 pm
Can somebody please give helpful ideas on removing old exterior paint. We are being lead safe but there has to be away to do this. Without scraping, sanding, more sanding, more sanding. I know it's hard work but theres got to be techniques to help, strippers, citrus oils, infared, pressure wash, any suggestions or some miracle formula.
kari74ob
Re: Exterior paint removal
Postby henrycarter139 on Tue Nov 21, 2017 1:44 am
I would give you the advice about paint removal. Paint thinner will take it right off. Go back over the area that you used thinner with some polish and everything will be fine.
henrycarter139
Postby irenejacob on Mon Dec 04, 2017 1:07 am
You can use stripping method by using proper tool to remove exterior paint of your house. It will be an effective method and you can try it.
irenejacob
Postby expressure on Mon Dec 11, 2017 2:45 am
Scraping is a tough process. try to remove the paint with propane blow torch, heat gun or electric sanders.
expressure
Postby doughty12 on Thu Dec 14, 2017 7:32 am
Use the search site function... There are many similar threads out there that could help you out. Some of them:
viewtopic.php?f=2&t=2444
viewtopic.php?f=4&t=11531
viewtopic.php?f=8&t=14819
viewtopic.php?f=2&t=4746
doughty12
Postby thekylieaustin on Tue Feb 27, 2018 4:39 am
I have a small cabin/shed that was painted 20 years ago. Now it is sun-worn and the paint is almost gone in the spots facing south. The cabin has false tongue-in-groove wood siding that is weathered and grayed. I want to reduce the siding down to raw wood so I can apply a stain to it. Should I use a chemical paint stripper, sand it or scrape it? There's about 400sq ft to prep so what's the best approach that is not crazy labor intensive to ready the wood for stain?
thekylieaustin
Postby alisondaewon on Tue Feb 27, 2018 5:40 am
alisondaewon
Postby gage on Wed Mar 07, 2018 3:06 am
Scraping is a tough process...
router 192.168.0.1 login, bullet force multiplayer
gage
Postby CaseyAdams on Fri Mar 09, 2018 12:57 am
Yes, scraping is difficult.
CaseyAdams
Postby miranda8 on Sun Mar 11, 2018 2:44 am
henrycarter139 wrote:I would give you the advice about paint removal. Paint thinner will take it right off. Go back over the area that you used thinner with some polish and everything will be fine.
100% agree
miranda8
Users browsing this forum: Google [Bot] and 1 guest
