bathroom walls
bathroom walls
Postby Peter K. Sinanian on Sat Apr 03, 1999 2:14 pm
Our house was built just after WWI. I am planning to remodel our bathroom. The lower half of the existing bathroom walls consist of wall tile and and the upper half is the original plaster and lath. The tile was very well done on a cement base and is in pretty good shape. However, the plaster walls above the tile (and the ceiling as well) are in bad shape. They are uneven and have a few large cracks. The sections around the tub have peeling paint caused by the shower steam, and the other sections have a thick coating of heavily textured paint. My question: Can I rip out the upper plaster sections and replace them with drywall without interfering with the tiled portions below? If so, how do I tear out the old plaster? Any advice as to the level of difficulty and time commitment this job presents to a novice would be greatly appreciated. One other question I have is how hard is it to clean, brighten and re-grout the existing wall tile, and what tools/materials exist for this type of job?
pksin@voicenet.com
Peter K. Sinanian
Re: bathroom walls
Postby Ken Holmes on Sat Apr 03, 1999 10:10 pm
Before answering your main question, I'd suggest one alternative: If the plaster is still firmly attached to the lathing but has a few cracks, I'd first try removing the texture paint. You might be able to saturate it with warm water and then scrape if off with a wide putty knife. Try a section. If this works but is too much work, try a wallpaper steamer. Then once you get all this goo off, sand the walls, patch the cracks and you're ready to go.
If the plaster is too far gone, you can remove it with a flat pry bar. I assume from your description the house has wood lathing. The plaster will come off fairly easily once you get going. (Be sure to wear a good mask or respirator, heavy clothes and leather gloves, though. And be ABSOLUTELY sure to seal off any ductwork -- and to seal off the room itself from the rest of the house. Plaster dust is nasty on the respiratory system -- and if you don't confine it to the room you're working in, it's a gift that keeps on giving. It'll get everywhere!)
The hardest part of this job, frankly, is doing a quality drywall job if you're a novice. You can read all you want about drywalling techniques, but the only way to learn to tape and mud walls decently is to do it. And frankly, your first room will, well, look as if it's your first room.
Some things that make the job a touch easier:
* Use water-resistant drywall.
* Buy the right tools, such as a full selection of drywall knifes, and one made for inside corners.
* Use self-adhering fiberglass tape instead of paper tape. It's easier.
* And use the super-whipped pre-mixed drywall mud. It doesn't shrink as much as traditional mixtures as it dries -- making it easier to apply.
As for re-grouting, it's a fairly easy job -- especially compared to those walls! You can use either a paint scraper with a triangular end, or get a tool specifically designed to loosen old grout. Someone at the hardware store or lumberyard can show you what to buy. Once you've removed the old stuff (a tedious but fairly easy job) then you mix up new grout, apply it with a nearly dry sponge and then clean up the mess afterward.
Good luck -- and again, unless the plaster is falling off those walls, try to work with it somehow rather than replacing it.
Ken Holmes
Re: bathroom walls
Postby J on Wed Apr 28, 1999 8:05 am
how about using the product Nu-Wall? will this work well on the lath & plaster? would it be difficult to work with?
jeri0790@inreach.com
J
Users browsing this forum: Bing [Bot] and 0 guests
