flooring
sivils11
flooring
Post by sivils11 »
We have found an old, VERY old, porch floor under interior tile that we've removed and plan to cover with a plywood floor. As expected in an old porch floor there are gaps between the boards. Our question is, in addition to laying a moisture barrier should we back paint/polyurethane the plywood?
jennifermartonllc
Re: flooring
Post by jennifermartonllc »
Should I ask one question which is why you are not going with concrete wood flooring because first, it is highly recommended for a quality work and with having a long life.
james1o1
Re: flooring
Post by james1o1 »
LVT flooring is durable, has a high resistance to moisture and stains, and is easy to maintain. LVT flooring Dubai is a sustainable and cost-effective option for all flooring projects. It has a high resistance to moisture and stains, is easy to maintain, and is made from recycled materials. This type of flooring has many benefits, including being easy to install and it is very cost-effective. In addition, it can be installed in any environment and it is easy to clean.
