Need help with Waterlox
chadzeilenga
Re: Need help with Waterlox
Post by chadzeilenga »
Now that we have the floors done we are planning the process of repainting and cleaning up each of the rooms but need some advice. We used waterlox on all of the floors, but are unsure about what to use on the trim. I'm thinking of taking down the trim and refinishing it, most of it is unpainted. Should I just use the waterlox on the trim too so that it matches the floors or should I use Shellac which is correct for the house and perhaps easier to maintain since it isn't a wear item like the floors? I think most of the trim already has shellac on it now, so it would be easy to remove and clean up. What is the best way to remove the trim without damaging it? I was thinking of using waterlox on the 1/4 round on the floor and shellac on the baseboards since the 1/4 round will most likely get waterlox on it when I recoat. Take a look at a few pics of the trim in the house.
1322 Benton 025.jpg (34.62 KiB) Viewed 3218 times
Post by Sombreuil_Mongrel »
I heartily endorse shellac for trim. Waterlox is thin. That makes it fine for horizontals, but verticals it would tend to drip. It is also slow to dry; in the time it takes to do 3 coats of WLX, you could do ten or more coats of shellac. Shellac will be dust free a lot sooner than the WLX. I think a very nice finish could be a first coat of oil, to bring out the grain, then shellac.
saaraah
storing waterlox
Post by saaraah »
i just finished putting on the 4th coat of waterlox on my pine floors..your floors look amazing, btw.
now im wondering how to properly store the unused portions because im worried about it oxidizing.
any suggestions? thanks!
ChrisF
Post by ChrisF »
I buy bags of marbles at the dollar store, then drop them in the container until the Waterlox is at the very top of the rim. Then put the cap on, and you're done. Depending on how much you have left, you may want to move the remainder to a smaller container...canning jars work great for this.
You can buy a product called "Bloxygen" to preserve the waterlox (or any oil-based finish) in the can. It is an inert gas that you spray into the partially-filled container to displace the oxygen.
philsvintageradios
Post by philsvintageradios »
I would just trim around the woodwork with a knife to make sure that when you remove you don't pull a nearby sheet of paint or wallpaper orr, then get under it with a small flat pry bar and take your time , pulling under the nails and moving end to end, if it cracks badly , pull the pieces right apart and glue and clamp them being careful to line them up exactly as they were. if nails pull right through , filler will fix that.
I did my floors with an oil based urathane, I don't know how similar waterlox is. I did the trim with the same felt pad technique as the floors while they were off and I could turn them flat. I just made a small pad with a bit of teritowel wrapped around a piece of lath and linen over that and it went on much nicer than a brush. I made the baseboards up though, and mine are flat.
the other tip that helped me is that I learned that I could use a bit off solvent on a piece of wet or dry paper to sand out any imperfections that bugged me , I found I couldn't sand with dry paper because it hadn't fully cured.. it would just ball up on the paper. To my surprise, the solvant didn't dissolve or harm the coating at all, even though the same solvent works as a thinner when the stuff is in a liquid state -the next day, it woun't affect it. I don't know if this is the same for waterlox. I guess it is because the finish catylizes , other finishes don't work quite that way.
I did tung oil first, then the finish and that worked very well for me. it soaks into the wood and hardens under the surface,then the finish acts like a shell over that. one thing I relly liked about this was that if I hit a spot where there was some glue or something, or if the filler color didn't match after the oil was applied I had time to fix it, and the wood wasn't as delicate with some sort of finish on it.
places I got caught were..
the rollers on the edger were too hard and left marks on the soft wood which showed in some spots. This showed up with the application of oil, but I still never got them all out. next time I will put rubber bands or something around the rollers to protect the soft floor.
I did my first coat on a warm summer day and it got warmer and I had really wished I added more thinner when I got about halfway across the floor and it started to stiffen up. by then it was too late to stop and thin the stuff more, and I had to go with it, I fixed it with a scraper and the sandpaper as above, but I did have some "waves" because it was to thick
hindsight taught me that if it goes on too thin , you might need another coat, but so what.. wheras, if it is too thick this is what happens. All in all I was very happy with it in the end. and I have a better idea as I go to do other rooms.
Phil
saaraah
Post by saaraah »
thanks for the suggestion.. i got some new rocks to put in the can. im happy that the waterlox wont be gelling.
rncx
Post by rncx »
i agree with casey on the trim. if you were putting up the trim after taking it down and pre-finishing it while laying flat it would be ok, but i don't think it would work well on vertical surfaces.
and you can use waterlox over or under shellac as well, they stick to each other just fine. one coat or two of waterlox for a sealer and then shellac over that leaves a pretty distinct and very nice looking grain.
LorenaBlairBOp
asiadate
Post by LorenaBlairBOp »
Stalker confronted married men after sleeping with them
The cougar from nightmare: Stalker targeted married men in uniform through online dating sites, Slept with them then insecure to tell their wivesSarah Lewis 'preyed' on men using an Ashley Madison style adultery websiteThe 49 year old, after Worcester, Lied about being pregnant and having an STIShe blackmailed a victim into leaving his dream job and split up another's familyBut a judge said she had 'low self esteem' and suspended her prison sentenceBy Paddy Dinham For Mailonline
authored: 10:10 EDT, 29 June 2017 new: 06:47 EDT, 30 June 2017
an obsessed person who used a 'cougar' dating site to have affairs with five married men while she was 'on a break' from her husband was spared jail because she just 'wanted to be loved'.
debbie Lewis, 49, 'preyed' on men using an Ashley Madison style adultery website before meeting them in hotel rooms for sex.
On one occasion she cried rape and on another she pretended she had get pregnant while also claiming to have caught an STI.
Another victim was so distressed he was close to suicide after Lewis confronted to show his wife a naked picture of him.
Pictured in this article: Stalker mother Sarah Lewis and husband Andrew soaking in a Jacuzzi
sarah Lewis, 49, 'preyed' on men using an Ashley Madison style adultery website before meeting them in resort rooms for sex
She also told one man's 12 yr old daughter her father was a 'sex pest.'
One firemen she had sex with was forced to leave his dream job after she threatened to sent intimate photos of him in his uniform to his boss.
Lewis, on Worcester, Admitted five counts of harassment by stalking and one count of disclosing private sexual pics or 'revenge porn'.
RELATED ARTICLES last 1 Next
he isn't going anywhere: the way Uber's ousted CEO Travis. Stalking victim who begged officers preserve her against. Paris gets an app warning people should they be in a 'no go'. firefighter is sacked after saying a black women with a.
But a judge refused to jail her after hearing Lewis targeted the men because she 'wanted to be loved' and had 'low self confidence.or,--
fairly, She was sentenced to 21 months in imprisonment, Suspended for two years and ordered to complete 15 days of a therapy activity requirement.
Lewis who was 'on a break' from her husband the moment was also given a two year mental health treatment order.
At her sentencing learning, Judge Nicholas Cartwright shared with her: 'Your behaviour is unpleasant, Predatory and likely.
'You used a man's 12 year old daughter as a pawn in repayment, telling her that her dad was a sex pest.
'You did that to buy at him.
'In relation to the impact on the victims it was profound in each case.
'One man became miserable and suicidal. His family has been separated.or,--
Lewis admitted five counts of harassment by stalking and one count of disclosing private sexual images or 'revenge porn'
Judge Cartwright also imposed a restraining order on the subject of the 11 victims affected by Lewis, since men, Their girlfriends or wives, And a child which will last for ten years.
The court heard Lewis already had two previous prosecutions for harassment in 2002 and 2003 and another of sending an article which was grossly offensive or indecent in 2014.
This placed her in breach of a conditional emit which she also admitted.
Prosecutor Michael Aspinall said Lewis got hold of the first man via a mingle2 reviews website for people seeking extra marital affairs, visiting him for sex in a hotel in Cheltenham, Gloucestershire.
Lewis made contact with men using the Saucy Dating contact site, Pictured, and the like
In July she threatened to tell the man's wife about the affair and he received messages which got from the Lewis' friends but were really from her.
Mr Aspinall said the person was 'pressurised' into meet her at a hotel in Lichfield, Staffordshire, On July 23 but the next morning found her taking pictures of his car and threatening to play her 'ace card'.
