In response to an e-mail, you were kind enough to explain how to best insulate our old house attic. We are now seriously considering finishing the attic. I’m guessing this would change how to insulate. Would we just put the insulation between the roof rafters, or am I missing something? If you have time, I would really appreciate some guidance.
Finishing an attic seems straight forward and simple, but there are some things to consider. Planning ahead, research, and correctly installing materials can help make an attic into comfortable extra living space.
Attic spaces are typically very hot in the summer and very cold through the winter. Without properly insulating, your finished attic room will also be cold in the winter. Without properly ventilating the roof, your finished space can be just as unpleasant as an unfinished attic. Since parts of a finished attic are usually very close to the roof, insulation often blocks proper ventilation that is needed under a roof structure.
Both of the above creates some spaces where a good amount of insulation can be installed and areas are created for ventilating under the roof. These spaces aren’t really useable in a room anyway.
Where insulation will have to be installed between the roof rafters, “baffles” should be installed first. Baffles hold the insulation away from the underside of the roof decking, creating a channel for air movement.
(6 votes, average: 4.67 out of 5)
10 Responses to “How to Insulate a Finished Attic”
Thanks for your article.
Would the same advise apply to the tin roof with no ridge vent?
Hi Kit,
Old metal roofs typically didn’t have any ventilation and have held up quite well. Ventilation could reduce moisture condensing under the roof though.
If you’re finishing an attic space under a metal roof, the living area can be quite uncomfortable on hot, sunny days. The ventilation and insulation I’ve described above would likely make it more comfortable.
please tell me if you have to insulate the walls in the attic,when you have insulation on floors, we have 4 vents in attic.
We have a big problem in our finished attic bedroom . The roof is facing north and we were having leaking problem. We took off the plywood and insulation and installed flo-thro(strofoam)vents, installed insulation again and plastic vapour barrier. We thought this would solve our problem until we had a mild spell following very cold weather and water started running down the ceiling inside the vapour barrier. Does anyone have any other suggestions? How much venting is required in the eaves and on the roof? We have vents at each end of the attic at the peak of the roof.
I’m finishing the second floor of a pre-fab home.There is a knee wall about 4′-9″ tall then the rafters (@4′-6″) upto the ceiling which is @ 8′ tall. Because the home is manufactured w/ 2×6 studs including roof rafters, there’s not a lot of space for batt insulation after installing the rafter baffle up above the ceiling height. Is this enough space for exterior wall rated insulation, or do I need to pad out this area to allow for more room for insulation/ refter baffle? Thanks
I have an attic in 150yr old home that is large enough to be used as third floor. How do I insulate and vent this? It has large beam work that I’d like to keep. Can I insulate from the exterior instead? And how would I ventilate? There is knee wall all the way around but ceiling goes to roof peak.
I want to insulate the roof rafters of an unfinished attic with intention of finishing the room eventually. The floor is not insulated. How do I vent using ventilation channels? What type of insulation foiled or not? Vapor barrier or not?
Thank you for that good post. I enjoy your website very much.
I have a cape cod style house (built in 1949) with no soffit vents, it does have gable and ridge vents. This home is NH. The finished attic area seems to be very hot and very cold during the year…The knee wall areas are insulated on the roof and possible the floor (we believe the floor area is insulated). What R rating insulation should we use if we decide to rip all of it out and start over? We also experience ice build up around the edges of our roof. No leaking yet. Any advice would be appreciated. Thanks.
