Question about siding that touches the ground
rawwebdesign
Post by rawwebdesign »
My garage is sided with like a wood siding and it's touching the ground. Here are some pics:
It gets damp and we have termites in our area (!). I'm trying to figure out the best remedy. Our neighbors have this:
The inside of our garage looks like this, if it matters:
Thanks so much for any suggestions!
Renaissance Restorations
Re: Question about siding that touches the ground
Post by Renaissance Restorations »
The 1st 6" should be metal flashing or PT lumber to prevent rot/insect damage.
JoeF
Renaissance Restorations LLC
35 Grove Ave
Leominster, MA 01453
http://www.renaissancerestorations.com
NickPool
Post by NickPool »
A metal, or stronger lumber siding would easily fix this problem. I'd think even a thin sheet of aluminum cut to the right size would work great.
SkipW
Post by SkipW »
Removing the first course of shingles and replacing with PVC or PT lumber would help. If you can re-grade the existing landscaping to lower the elevation and make sure it slopes away from the building would help too.
Is the lowest course hanging over the slab or just over the diag sheathing? If concrete, that is better and you could just remove the wood shingles and expose the concrete.
rawwebdesign
Thank you so much for your responses. I'm going to try to find someone locally to help me take care of this.
